1992 Toyota Camry Valve body assembly
RATSUN
Transmission problem
1992 Toyota Camry 6 cyl Front Wheel Drive 265000 miles
Hi there, have a problem where when I took the bottom cover off the valve body on auto trans A540-1a to fit new kick down cable I discovered 2 plastic balls had fallen out on dismantling. I have no Idea where they go in the valve body. any help on this would be much appreciated. Many thanks.
Jul 12, 2010 at 8:38 PM
  • 75,988 POSTS
Sounds like check balls you need to find where it goes otherwise the tranny is not gonna function correctly see below
https://images.2carpros.com/forum/automotive_pictures/12900_check_balls_1.jpg
Jul 12, 2010 at 8:56 PM
