Saturday, August 15th, 2009 AT 4:57 PM
I'm having a problem with my 92 Toyota Camry V6. The problem is that whenever I drive for more than 10 minutes, my car stops moving. The engine is still running, but when I press on the gas, it just doesn't move. It revs up, but the car just doesn't move. This is the same if I try to change it to reverse. It just revs up without moving. The area around my feet where the gas pedal is gets really hot as well. Any idea what could be causing the issue?
