Thw transmission won't go into any gear(P,D) after starting the engine. Sometines only engages to move a few feet. Fluid is not low.
Jan 10, 2010 at 3:59 PM
DAVE H
✓Experienced Mechanic
Hello .. thanks for the donation .. much appreciated
You really need a transmission shop to check the vehicles transmission .. this fault is an internal pressure loss somewhere and the trans will probably need to be replaced or rebuilt i'm afraid .. could be a bad solonoid/valve/pump etc .etc.
