1992 Toyota Camry RADIATOR
DMILLERKNUTH
  • 1992 TOYOTA CAMRY
1992 Toyota Camry
THE RADIATOR BLEW UP, (SPLIT ON TOP).
WE REPLCAED THE RADIATOR, 2 DAYS LATER THE RADIATOR BLEW AGAIN, IN THE SAME MANOR. THE CAR HAD ONLY BEEN RUNNING A SHORT TIME AND SHOWED NO SIGNS OF BEING OVER HEATED.
Wednesday, March 17th, 2010 AT 9:03 AM
RACEFAN966
  • 5,029 POSTS
So have you done a chemical test to make sure that the head or head gasket are not bad? If not do that that this will answer weather or not it is more serious then just a cap or thermostat.
Wednesday, March 17th, 2010 AT 10:39 AM
