1991 Toyota Camry the right engine starter
ITMERO
  • 1991 TOYOTA CAMRY
Electrical problem
1991 Toyota Camry 6 cyl Two Wheel Drive Automatic
I am looking to purchase a battery charger with engine start, I just want to be sure if I will be buying the right one. My main fuse rating is 150 Amps (it is located on the positive terminal of the battery), what rating of engine starter pack/unit should I buy? Will a 100 Amp engine starter work? An 80 Amp? 150Amp? Or it should higher than 150Amp? I just wanted to buy a unit that is sufficient enough to start my battery in case it gets drained. A higher ampere rating is really expensive
Thursday, August 26th, 2010 AT 8:13 PM
SATURNTECH9
  • 30,869 POSTS
Why don't you just get a jumper box there even portable and don't need a plug to work.I never use a battery charger to jump a car because if your battery is dead or bad enough the battery charger with jump start isn't going to be strong enough to start the car. You also need a plug near by your best bet is a jumper box.
Thursday, August 26th, 2010 AT 8:19 PM
