STARTER MOTOR
Removal & Installation
Disconnect negative battery cable and then positive cable. Remove battery and tray. If equipped with cruise control, remove cruise control actuator cover, cruise control actuator, and actuator bracket from body mount.
Remove starter terminal/wire cover and remove starter wires. Remove starter. To install, reverse removal procedure. Tighten starter mounting bolts to 29 ft. Lbs. (39 N.M).
Saturday, April 25th, 2020 AT 1:04 PM
