At first the car made that typical bad stater noise. Now I get nothing when I turn the key, no noise, nothing. Sometimes it will start, other times not. So my question is do you think its the starter and if it is where is it in the engine, I would like to change it myself if I can
SPONSORED LINKS
Wednesday, August 27th, 2008 AT 10:50 AM
BMRFIXIT
MECHANIC
Sounds like a bad starter
check list before u replace the starter
charge battery, check terminals and fuses
locate starter under the intake manifold side
check wires and connectors
