1990 Toyota Camry 4 cyl All Wheel Drive Automatic
The signal that lets us know if a door is open on the dashboard is on all the time which is draining my battery. I know there is a "sensor" on driver side on the frame which when you close the door it should prevent the "door open" signal to light up. What is the correct name of this "sensor" by the door frame called so I can order the part?
SPONSORED LINKS
Thursday, September 11th, 2008 AT 6:44 PM
