1997 Toyota Avalon Shift Solenoid
LAURA1968
I have a 1997 Toyota Avalon XLS, Miles are 155,239.
I had the engine check light come on and had it checked by a friend who had a meter who works at a Toyota dealership- it showed that I had a faulty transmission shift solenoid.
How do I go about replacing this?
Mar 29, 2006 at 7:05 AM
  • 55,649 POSTS
Hey LAURA1968,
Here is a guide and a diagram on how to fix the problem. You must remove the transmission pan
The shift solenoid is internal to the transmission. You have to know which one. Here is a wiring diagram that shows which one to replace.
Please let us know happens so it will help others.
Best, Ken
Jan 3, 2017 at 3:31 AM
Suggested Repair
Remove the transmission pan to access the internal shift solenoid. Identify the specific faulty solenoid from the wiring diagram, then replace that solenoid.
Conversation Summary
The owner of a 1997 Toyota Avalon XLS with 155,239 miles had a check engine light. A dealership employee checked it and reported a faulty transmission shift solenoid. The expert said the solenoid is inside the transmission, so the pan must be removed and the correct solenoid identified from the wiring diagram before replacement.
