95 Toyota Avalon 3.0 liter V-6 oil in air filter
1995 TOYOTA AVALON
AGENTMAX
My Avalon keeps fouling air filters with oil from the engine, to the point that oil pools at the bottom of the housing that holds the air filter. My mechanic checked and cleaned the PCV system but says the rings are bad and would require an engine rebuild. The car doesn't smoke like it's burning oil, though it sometimes smells oily and hot inside the car. There are 140,000 miles on the car and I'm wondering if the rings seem like the logical source of the problem.
May 4, 2007 at 7:32 AM
[quote:bd2db0f3f0="agentmax"]My Avalon keeps fouling air filters with oil from the engine, to the point that oil pools at the bottom of the housing that holds the air filter. My mechanic checked and cleaned the PCV system but says the rings are bad and would require an engine rebuild. The car doesn't smoke like it's burning oil, though it sometimes smells oily and hot inside the car. There are 140,000 miles on the car and I'm wondering if the rings seem like the logical source of the problem.[/quote:bd2db0f3f0]
Get a compression check to rule out the rings
There's 4 things that can do that in my experience-
1.PCV valve plugged
2.Leak in the crankcase ventilation system
3.Cylinder head oil return holes plugged
4.Valve cover oil baffle restricted.
HTH Good Luck
May 4, 2007 at 8:03 AM
