2003 Toyota Avalon Timing belt camshaft grear
2003 TOYOTA AVALON
EDTIGER
Engine Mechanical problem
2003 Toyota Avalon 6 cyl Front Wheel Drive Automatic
the camshaft grear on the right side of the engine broke off causing the belt to break would need a new camshaft and could my valve be bent
Nov 9, 2008 at 11:47 AM
  • 31,937 POSTS
Hi there,
You should be able to extract the broken bolt and the cam should be serviceable, the bad news is the engine will have bent valves, you will have to check all cylinders.
mark (mhpautos)
Nov 9, 2008 at 11:55 AM
EDTIGER
can i do a compresion test to check if the vavle are bent
Nov 9, 2008 at 12:01 PM
  • 31,937 POSTS
Yes you can, but you will have to re time the engine and fit a new belt first.
Mark (mhpautos)
Nov 9, 2008 at 12:18 PM
EDTIGER
if i would get a shop to fix the belt how much u think it would ru u think
Nov 9, 2008 at 12:38 PM
