toyota 4runner
JOHN KASLIK
I have a 1994 toyota 4runner 88,000 miles, I have a problem with opening the reae window/door. When I try to open rear window with the key or button in cab I hear a small click and nothing happens I have never had any problem with the door before and I am sure that the electric motor hasnt burnt out Can you sujest anything Thank you john
Jul 21, 2007 at 9:23 AM
  • 75,988 POSTS
[quote:261853e64c="john kaslik"]I have a 1994 toyota 4runner 88,000 miles, I have a problem with opening the reae window/door. When I try to open rear window with the key or button in cab I hear a small click and nothing happens I have never had any problem with the door before and I am sure that the electric motor hasnt burnt out Can you sujest anything Thank you john[/quote:261853e64c]
Could be the rear power window control relay
Jul 21, 2007 at 9:29 AM
JOHN KASLIK
[quote:d4f4d3ae57="rasmataz"][quote:d4f4d3ae57="john kaslik"]I have a 1994 toyota 4runner 88,000 miles, I have a problem with opening the reae window/door. When I try to open rear window with the key or button in cab I hear a small click and nothing happens I have never had any problem with the door before and I am sure that the electric motor hasnt burnt out Can you sujest anything Thank you john[/quote:d4f4d3ae57]
Could be the rear power window control relay[/quote:d4f4d3ae57]
thanks for advice could you tell me how to identify the rear power window relay and where is it situated
thanks john I have checked the cable going to the motor and there is no power.Forgive me for being so stupid but I cannot still locate the PWCR could you explain in simple terms Also someone has sugested it could be the regulator regards john
Jul 22, 2007 at 7:27 AM
  • 75,988 POSTS
The PWCR is behind the left qtr. panel inner trim panel. Motor is left side of rear door.
Jul 22, 2007 at 8:35 AM
