radio antenna will not retract
TOYOTA 4RUNNER
CODYLYNCH
2000 toyota 4runner, when ever the engine is turned on the antenna make a grinding sound. It is fully extended, but will not retract.
Aug 17, 2007 at 3:15 AM
2CARPRO JACK
  • 11,533 POSTS
It has probably got a broken mast assembly. There is a toothed piece of plastic that goes down into the motor, if the antennae is bent and cant move freely, it usually breaks the mast assembly.
Aug 18, 2007 at 12:36 AM
