1990 Toyota 4Runner Charge and Brake Lights
KEYSTONE4R
I have a 90 4runner with 200,000 miles. The brake and charge light started coming on at the same time. They both go off at the same time while going uphill. Any idea where I might look for the bad wire?
May 13, 2006 at 9:14 AM
LOSONE
  • 1,616 POSTS
The brake light is Toyotas way of telling you that you have a charging problem. They figured a brake light on would make you take notice and it worked. I think you have a bad or nearly bad alternator. Have someone check it out.
May 13, 2006 at 11:45 AM
KEYSTONE4R
I had the plug on the alternator go bad, and just the idiot light for the charge system came on. This seems more like an occasional short. Parked facing uphill, the lights sometimes go off, but as soon as I get it level or downhill, they come back on. I'm wondering where to look for a wire that would kill the charge and bring the brake light on.
May 13, 2006 at 12:14 PM
LOSONE
  • 1,616 POSTS
I don't think what you have going on is a short if so it would blow a fuse. I think it is a ground problem. I would check all grounds from the battery to the engine, engine to fire wall and battery to frame. Remove and clean as often there is a disimiliar metal problem that causes corroision.
For many years Japanese vehicles have had a system where a fuse opens or there is a loss of a light or voltage and odd light will light on the dash. I have seen this the early 70's. Good luck
May 15, 2006 at 12:37 AM
Suggested Repair
Have the alternator and charging system checked. Also inspect and clean the grounds from the battery to the engine, engine to firewall, and battery to frame, since corrosion or a poor ground can cause both lights.
Conversation Summary
A 1990 Toyota 4Runner with 200,000 miles shows the brake and charge lights together; they sometimes go off when facing uphill and return when level or downhill. The owner suspected a bad wire or intermittent short. The expert said the brake light indicates a charging problem, likely a failing alternator, and that a short would usually blow a fuse. They recommended checking and cleaning the battery, engine, firewall, and frame grounds because corrosion can cause voltage loss and odd dash lights.
