1994 Toyota 4Runner Backup Lights Out
CAGRL127
1994 Toyota 4Runner
3.0 V6 4WD
185.000 miles
I checked the fuses and the bulbs, and both are just fine. What else could it be!?!
Help me please!
Thanks, Jen
Mar 11, 2007 at 12:00 PM
SERVICE WRITER
  • 9,123 POSTS
I would check for a ground problem- G904-under the left rear pillar.
Mar 11, 2007 at 1:21 PM
  • 75,988 POSTS
[quote:0502a3acf8="Service Writer"]I would check for a ground problem- G904-under the left rear pillar.[/quote:0502a3acf8]
OR
Find the ground on the socket splice in and find a good body ground back there should come On if its a ground problem
Mar 11, 2007 at 5:18 PM
Suggested Repair
Check ground G904 under the left rear pillar. If needed, locate the ground at the socket splice and connect it to a good body ground in the rear.
Conversation Summary
A 1994 Toyota 4Runner owner reported that the backup and license plate lights do not work even though the fuses and bulbs tested fine. Experts recommended checking for a ground problem at G904 under the left rear pillar, or splicing the socket ground to a known good body ground.
