Hesitates on soft acceleration
DGM
  • TOYOTA 4RUNNER
Toyota 4-runner, 2002, 3.4 liter automatic, 65000miles, 4wd.
soft acceleration hesitation.
hard acceleration OK, idling OK, starting OK
Could it be:
bad gas? Vacuum leak? Sticking linkages? Plugged fuel ports? Clogged air filter or other problem with air intake? Bad fuel pump? Bad fuel filter? Electronics? Spark plugs?
Friday, August 31st, 2007 AT 8:16 AM
When was it last tune-up
Could be a bad TPS/MAF/dirty injectors/vacuum leak/low fuel pressure. Hook-up a scan tool and view the parameters data stream what exactly are they doing.
Saturday, September 1st, 2007 AT 11:29 PM
