1996 Toyota 4Runner Idle Miss
JOSHKERCH
My 1996 SR5 V6 4Runner has 148,000 miles and misses at idle speed / when the RPM's are low. For example, when I am going about 50mph, and the RPMs are around 2,000. I will try to acclerate and the engine misses. It runs smoother as soon as it downshifts and the RPMs increase. It will also miss when I am just sitting there idle. I had the timing belt replaced at 120,000 miles. The transmission was flushed, and the fuel filter was also replaced very recently. I also just replaced the spark plugs and wires. My next step will be to replace the ignition coil packs. Hopefully that will fix the problem, and I won't need a compression check. But I would appreciate any advice.
May 2, 2007 at 3:03 PM
  • 75,988 POSTS
I won't need a compression check. You do
The compression check is done to evaluate the condition of the engine. You can throw new parts to it and if there's a problem internally your right back to square one.
My advise is to check the actual fuel pressure-and these CTS/TPS/MAF sensor-to include the VSS.
Engine in perfect condition, it leaves the fuel and ignition wide open-diagnosis should be in order for this two to get to the problem and who knows it might be coming from an emission control devices.
Good Luck
May 2, 2007 at 7:05 PM
Suggested Repair
Do a compression check before replacing more parts. Also verify fuel pressure and test the CTS, TPS, MAF, and VSS, and consider emission-control devices if fuel and ignition checks are inconclusive.
Conversation Summary
A 1996 Toyota 4Runner with 148,000 miles misses at idle and at low RPM, then runs smoother when RPM rises. The timing belt, fuel filter, spark plugs, and wires were already replaced, and the owner planned to replace ignition coil packs to avoid a compression check. The expert said a compression check is still needed to assess engine condition, and advised checking fuel pressure plus the CTS, TPS, MAF, and VSS, noting an emission-control device could also be involved.
