1995 Toyota 4Runner Clutch Pedal Fade
N2MONEY
1995 Toyota 4Runner 4x4, with 168k miles. The clutch will at times fade when being pressed down like in traffic. At times when sitting at a stop light the pedal will fade completely out and the vehicle will start moving or die. I can then put my foot under the pedal, move it forward then pump it and it starts working fine again. The problem is irregular and does not happed regularly but is becoming more regular. I cannot find any leaks in the lines and the fluid is full. What is going on and how can I fix it.
Aug 5, 2007 at 4:38 PM
  • 31,937 POSTS
Hi there,
If you are sure that there are no leaks in the system, (peel back the rubber boot on the slave and have a good look there) The master cyl may be by passing fluid past the pressure seal. If the car wants to move off as the pedal is de pressed the pressure is forcing fluid back passed the seal and into the resivoir, so you will not notice any fluid loss.
Mark (mhpautos)
Aug 5, 2007 at 5:39 PM
Suggested Repair
Inspect the clutch slave cylinder under the rubber boot for hidden leaks. If none are found, suspect the master cylinder pressure seal bypassing fluid back into the reservoir and replace the master cylinder.
Conversation Summary
A 1995 Toyota 4Runner with 168k miles has an irregular clutch pedal that fades when pressed, sometimes going to the floor at a stop so the vehicle creeps or stalls. Lifting and pumping the pedal restores function. Fluid is full and no external leaks are visible. The expert advised checking under the slave cylinder boot and said the master cylinder may be bypassing fluid past its pressure seal into the reservoir, which would not show as fluid loss.
