2000 Toyota 4Runner Clutch Slipping
MEGAN_29
toyota 4runner sr5 2000, 184000 mil., 4wd, manual.
loud engine reving, except when clutch is in. Also car slid about 3 ft. over night while parked in gear wlth parking brake set.
she has no apparent leaks.
last work done was front axel, and tie rods.
Aug 19, 2007 at 10:52 AM
  • 75,988 POSTS
[quote:4df75f5294="megan_29"]toyota 4runner sr5 2000, 184000 mil., 4wd, manual.
last work done was front axel, and tie rods.[/quote:4df75f5294]
The way you describe it is sounds like the clutch is slipping big time-You need a new clutch assy.
Aug 19, 2007 at 1:03 PM
Suggested Repair
Replace the clutch assembly; the symptoms indicate the clutch is slipping badly.
Conversation Summary
The owner of a 2000 Toyota 4Runner SR5 manual reports loud engine revving except when the clutch is depressed, and the vehicle rolled about three feet overnight while parked in gear with the parking brake set. No leaks were noted, and recent work involved the front axle and tie rods. The expert says the clutch is slipping and a new clutch assembly is needed.
