1994 Toyota 4Runner Transmission Slips
CCAMERO
  • 5 POSTS
I have a 94 4Runner 4x2 with 6 cyl. engine, automatic with 160K on it. The problem is that after the SUV warms up or after driving for a while and after a brief stop to drop some friend, the transsmision slips when I put it on the D, but it woked again if I started from 1, then 2 then D, A mechanic changed a sensor and it don´t fail so much anymore, but it still happen sometimes. I changed the trany oil and filter last February and it came out clean, no debris or metal dust. Do I need to overhaul the trany or its just another sensor thing?. Thanks in advance for your help.
Jul 27, 2007 at 12:29 PM
  • 75,988 POSTS
[quote:a9c099f749="ccamero"]I have a 94 4Runner 4x2 with 6 cyl. engine, automatic with 160K on it. The problem is that after the SUV warms up or after driving for a while and after a brief stop to drop some friend, the transsmision slips when I put it on the D, but it woked again if I started from 1, then 2 then D, A mechanic changed a sensor and it don´t fail so much anymore, but it still happen sometimes. I changed the trany oil and filter last February and it came out clean, no debris or metal dust. Do I need to overhaul the trany or its just another sensor thing?. Thanks in advance for your help.[/quote:a9c099f749]
Bring it back to mechanic to check the sensors involved/shifting solenoids before you think overhaul.
Jul 29, 2007 at 5:55 PM
CCAMERO
  • 5 POSTS
Just to update (after all this time!) so everybody knows.
I did what you suggest, but take the 4Runner to other shop and they change other of the solenoids and that fix the problem. Is still working to date.
Nov 5, 2010 at 5:34 PM
Suggested Repair
Check the transmission sensors and shift solenoids before considering an overhaul. Replacing a shift solenoid resolved the intermittent slip into Drive after warmup.
Conversation Summary
The owner of a 1994 Toyota 4Runner reported the automatic transmission slipping when shifted into Drive after warmup, although selecting 1, then 2, then Drive worked. The fluid and filter were clean, and replacing one sensor reduced but did not eliminate the problem. An expert advised checking the sensors and shift solenoids before considering an overhaul. Another shop replaced a solenoid, which fixed the issue.
