1997 Toyota 4Runner 4WD Won't Engage
yes it can the vaccume switch is on the pass side under the hood around the fuse box, to find out witch one (I think if I remember right think there are 2 or 3 switchover valves) follow the vaccume line down to the frt axel, or the line may be broken somewhere, bypass the switch and see if it enguages, if it doesnt the axel unit is bad
Suggested Repair
Inspect the vacuum switch on the passenger side under the hood near the fuse box and follow the vacuum line to the front axle. Repair any broken line. Bypass the vacuum switch to test engagement; if the front axle still does not engage, the front axle unit may be bad. This can be a home repair.
Conversation Summary
The owner of a 1997 Toyota 4Runner with a manual 4WD system says it recently stopped engaging. Shifting into 4WD feels like it adjusts, but the dash light does not come on and the front wheels do not engage, with a conflict between front and rear. The expert says the vacuum switch near the fuse box, a broken vacuum line, or the front axle unit may be at fault and that it can be repaired at home by tracing the line and bypassing the switch to test. The owner asked what bypassing the switch means, and no further reply was given.
