1994 Toyota 4Runner 4WD Shifter Stuck
QUERCUS
My 4Runner has 160K. It has purred like a kitten for most of it's years. However, my 4-wheel drive shifter no longer functions. It's as if it is frozen. The transmission is manual. Engine is 6 cylinder. I have tried to rock into 4 wheel, but that has not worked. I am unable to budge it, thus no light on the dash and no power to the two front wheels. My mechanic didn't have any luck, but he works on Alfa/Subaru's; I had the latter prior to 94. Any suggestions? I am looking to sell ASAP, as I have bought a new Ridgeline. Thanks! -Peter Morse
Jul 21, 2007 at 4:26 PM
2CARPRO JACK
  • 11,533 POSTS
Manual t-case i take it.Try getting under it and unhooking the shifter to move the t-case linkage by hand, this will tell if it is the shifter or the t-case.
Jul 22, 2007 at 12:32 AM
Suggested Repair
Get under the vehicle, unhook the 4WD shifter, and try to move the transfer-case linkage by hand. This distinguishes a seized shifter from a stuck transfer case.
Conversation Summary
The owner of a 1994 Toyota 4Runner with a manual transmission reports that the 4WD shifter is frozen and will not engage, with no dash light and no power to the front wheels. An expert recommends disconnecting the shifter and moving the transfer-case linkage by hand to determine whether the shifter or the transfer case is at fault.
