simple question about a button by the gear shifter
TOYOTA 4RUNNER
MATTINGLY267
i just bought a 94 toyota 4 runner and it has a button below the floor shifter when i push it a light on the dash reads ect.pwr does anyone know what it means? thanks
May 29, 2006 at 3:08 AM
LOSONE
  • 1,616 POSTS
When you push the button while driving does it go out of overdrive? It sounds like a an OD button.
On some vehicles I have seen a power button which gives you a little wider injector pulse width of fule to the injectors for towing or heavy work. For sure you will use more fuel
May 30, 2006 at 10:51 AM
MATTINGLY267
its not the overdrive button its on the gear shifter must be the power button.
May 31, 2006 at 1:22 PM
