96 4x4 4Runner SR5 4WD does not work.
1996 ALL OTHER MAKES ALL OTHER MODELS
SURFDADDY
My 96 4Runner 4WD does not work. It feels like it good movement of gears when I shift but the light does not come on and the front wheels don't spin. Used it extensively in a bad snow storm last year but not really since. About once a month I put it into gear to lub system, but may not have done it enought. I checked the fuse and it is OK. I also looked at the wiring but maybe not completely. I will be taking it into Jiffy Lube tomorrow.
Jan 27, 2007 at 1:46 PM
2CARPRO JACK
  • 11,533 POSTS
Not too sure if I would go to Jiffy Lube to have my car worked on, maybe oil change.Anyway, If the lever feels good slide under it and give a look at all the connections under at the transfer case.Start with the easy stuff
Jan 28, 2007 at 12:30 AM
SURFDADDY
[quote:b95f06cdca="2CarPro Jack"]Not too sure if I would go to Jiffy Lube to have my car worked on, maybe oil change.Anyway, If the lever feels good slide under it and give a look at all the connections under at the transfer case.Start with the easy stuff[/quote:b95f06cdca]
Just going to Jiffy Lube for Oil. Thanks for the advice, I will dig into it.
C
Jan 28, 2007 at 10:32 AM
