I have a 1998 F-150 4.6L, auto trans, 4WD, with 140,000. The front axle would not engage, I checked the fuses,OK. Check the front axle, and noticed the soleinod or plunger would not move. The transfer case works OK and shifts into and out of low gear. Should I remove the this plunger unit and bench check? Is it 12V? Thank you, rnd.
May 6, 2007 at 3:47 AM
