1999 Toyota 4Runner timing belt
JESSTHEPITT
  • 1999 TOYOTA 4RUNNER
  • 6 CYL
  • 4WD
  • 135,000 MILES
I'm changing the timing belt on my 4 runner, I got it off and changed the water pump. But I cant get the new belt back on because I dont know how to get the tension off the hydrolic tensioner. Any help would be great.
Thursday, October 16th, 2008 AT 9:45 PM
2CARPRO JACK
  • 11,533 POSTS
You will need a vise to compress it. Once it is compressed, you will need a hard pin to hold it that way so that you can instal it. You can use a small drill bit to hold it.
Thursday, October 16th, 2008 AT 11:40 PM
JESSTHEPITT
Thanks for the responce, I ended up just going and getting a book. I was just dreading taking off the darn ac pump, but I had to. Well thanks again
Friday, October 17th, 2008 AT 12:52 PM
