1995 Toyota 4Runner wont start
CHEVROLETCOWBOY80
  • 1995 TOYOTA 4RUNNER
Engine Mechanical problem
1995 Toyota 4Runner 6 cyl Four Wheel Drive Automatic
The vehicle turns over strong but just wont start. I at first thought my friend ran it out of gas but even after adding fuel it still just turns over.
Sunday, November 29th, 2009 AT 9:18 AM
Get a starting fluid/ether/better off gas in a spray bottle and spray into the carb or the throttle body on an EFI. Did it start and die? If not disconnect a sparkplug wire or 2 and ground it to the engine -have helper crank engine over-do you have a snapping blue spark? If so-you have a fuel related problem, check the fuel pressure to rule out the fuel filter/fuel pump/pressure regulator and listen to the injector/s are they pulsing or hook up a noid light. No snapping blue spark continue to troubleshoot the ignition system-power input to the coil/coil packs, coil's resistances, cap and rotor /distributor pick-up coil, ignition control module, ECM, Ignitor camshaft and crankshaft sensors- Note: If it doesn't apply disregard it
Sunday, November 29th, 2009 AT 10:41 AM
