1995 Toyota 4Runner engine do not run
TAN
Engine problem
1995 Toyota 4Runner V6 Wheel Drive Type unknown Automatic 139000 miles
I have a toyota 4runner 1995, mileage ; 139000
One day I forgot car key inside , the day after battery gone out , I tried to jump starte by the other car but I make mistake ( wrong pole + - ) the fuse Alt 80 A blowed , I replace the new one , and after that repeat jump battery but when turn on , stater work , engine do not run , I don't know what going on , and what I have to do now
Dec 2, 2007 at 9:20 AM
  • 31,937 POSTS
Hi there,
Check for any other fuse and fusible links at the battery, have a fault code read. With flashing the battery like that, you may off spiked the ECU. A code read should give a clue as to what damage has been done.
Mark (mhpautos)
Dec 2, 2007 at 11:14 AM
TAN
[quote:da5931ff39="mhpautos"]Hi there,
Mark (mhpautos)[/quote:da5931ff39]
Thak for your help , but until now engine still do not run , I don't undestand what is off spike the ECU, a fault code read, and how to do that , please show me again Thank-you so much
Dec 4, 2007 at 7:13 AM
