1995 Toyota 4Runner timing
SPIKE1990
  • 1995 TOYOTA 4RUNNER
Engine Mechanical problem
1995 Toyota 4Runner 4 cyl Four Wheel Drive Manual
how do I know if the timing jumped or broke because my truck wont start and it is rolling over very fast?
Friday, August 20th, 2010 AT 8:43 AM
  • 31,937 POSTS
Check that the valve timing is correct by removing the rocker cover and with the engine on TDC No1 the cam timing mark(a dot on the gear) should be at 12 O'clock, start here.
Mark (mhpautos)
Friday, August 20th, 2010 AT 10:29 AM
