One of these could be out of specs causing the low dry compression.
When the dry compression test was made, was the engine not running for an extended period of time?
Did you retest the compression after running the engine again?
With 2700 miles on the engine, there is a possibility the block has not run in yet and that couls be the cause of the low compression as well.
What grade of engine oil is used?
Tuesday, March 9th, 2010 AT 10:54 AM
