I am repairing my friends 4runner and there is an obvious short to ground, the 40 amp B+ fuse blows readily when the + terminal is touched to the battery longer than the time required to generate some sparks- it's almost enough to weld the terminal to the battery...so when disconnecting the B+ from the alternator bolt the symptoms of sparking goes away completely.
Also for some strange, and possibly related issue, the wipers are stuck ON and in one speed. adjusting the speed control to off or other positions makes no difference.
Incidentally, when trying to start the vehicle ( with the B+ unhooked from the alternator) it doesn't fire at all .
Thanks for any help. -Paul, in Ohio.
Sep 13, 2008 at 9:58 AM
