1997 Toyota 4Runner Battery Drain
ROLLINON
My 1997 toyota 4 runner 170,000 miles has an electrical problem. I thought it was the alternator because the battery went dead and it would run on the alternator alone so I replaced alternator to find it still died after battery lost charge so I'm thinking battery and had it checked out because it was a month old. I'm now lost and thinking a short between battery and alternator but don't know can anyone relate to this problem?
Sep 3, 2007 at 7:51 AM
SERVICE WRITER
  • 9,123 POSTS
There may be a parasitic draw on the system draing down the battery when it is setting, It may be a light that is left on or a problem in one of the circuits. Too much pull from the battery will results in a no crank.
Need to verify the battery is good after a full charge and the alternater is good. OR start checking for a excesive draw.
Sep 4, 2007 at 10:31 AM
Suggested Repair
Fully charge and retest the battery, confirm the alternator is charging, and check for a parasitic draw such as a light left on or a circuit pulling excessive current while the vehicle sits.
Conversation Summary
The owner of a 1997 Toyota 4Runner with 170,000 miles reports the battery goes dead and the vehicle dies after the charge is lost. Replacing the alternator did not fix it, and a month-old battery tested okay, so a short between the battery and alternator is suspected. The expert says a parasitic draw may drain the battery while parked, possibly from a light left on or a faulty circuit, and advises verifying the battery after a full charge and the alternator, or checking for excessive draw.
