1987 Toyota 4Runner Starting problems
TOYOTA59
Engine Performance problem
1987 Toyota 4Runner 4 cyl Four Wheel Drive Manual
When I go to start my truck it takes a few minutes for it to crank .. The engine turns over fine .. I checked the plugs and there firing , I just put a new fuel pump in and filter , plugs and plug wires , someone suggested that it might be the coolant temperature sensor , so I replaced that too and it would crank up fine for about a week. Now It's doing the same thing , I checked the codes and the only thing that comes up is a code 11 which means,
" switch signal -neutral start which on 22re or idl point in throttle position sensor is off during diagnostic check " .
I would like to know is would that code make it not run ? It starts fine and when it does crank it runs good , It just has a hard time starting
May 7, 2008 at 4:48 AM
ROB2008
  • 258 POSTS
The one thing I would check first would be the coolant temp. sensor . Sense you just put it on It probably works good ,but check the connections .
-Rob
May 7, 2008 at 12:14 PM
TOYOTA59
WOW , thanks you were exactly right !! . It was the connections . I'll tell more people about this site . Thanks again .
May 7, 2008 at 12:30 PM
