2017 Hyundai Sonata Valve Cover Torque Fix
96,000 MILES • 2.0L • 4 CYL • 2WD • AUTOMATIC
AXE12
Torque specs for valve cover gasket replacement needed and the order to adjust the bolts.
Dec 19, 2024 at 10:19 AM
STEVE W.
  • 15,421 POSTS
The specs are in two steps. First pass is to 3 to 5 lb ft. for each bolt.
The second pass is to go to 7 lb.ft. following the same pattern.
Don't forget the small bead of sealer at the ends of the head as shown 2.5 mm and let it set no more than 5 minutes.
Dec 19, 2024 at 12:59 PM
AXE12
Torque specs for valve cover gasket replacement needed and order for adjustment the bolts
Dec 29, 2024 at 6:45 AM (Merged)
MECHTRIX
  • 599 POSTS
9.8 NM is good i bit on the tight side but good
MECHTRIX
  • 599 POSTS
9.8 nm Or about 7.25 ft p. 10 nm is 7.37 ft p that's what I do them at ..never had any issues.. good luck
Suggested Repair
Tighten the valve cover bolts in two passes using the same pattern: first to 3-5 lb-ft, then to about 7 lb-ft (roughly 9.8-10 Nm). Apply a 2.5 mm bead of sealer at the ends of the head and install within 5 minutes.
Conversation Summary
The owner of a 2017 Hyundai Sonata asked for valve cover gasket torque specs and the bolt adjustment order. One expert recommended a first pass of 3-5 lb-ft and a second pass of 7 lb-ft in the same pattern, plus a 2.5 mm sealer bead at the head ends with no more than 5 minutes of set time. Another expert said about 9.8-10 Nm, or roughly 7.25-7.37 lb-ft, works well.
