Need a diagram of the torque sequence for the valve cover/valve cover gasket.
Apr 18, 2023 at 6:24 AM
Follow the valve cover bolt torque sequence in the service diagram and tighten to the specified values in inch-pounds, not foot-pounds.
The owner of a 2014 Buick Encore asked for the valve cover and valve cover gasket bolt torque sequence. The expert noted the cover uses many bolts and referred to diagrams for the sequence and torque specifications, emphasizing that the torque is given in inch-pounds rather than foot-pounds.
