This car is in good condition. The passenger side tire wears much faster than the driver side and more wear is seen on the outside of that tire. What could be the cause of this? I had it in for alignment and was told everything looked good though they did make a slight adjustment to the toe-in. This is the second set of tires this has occurred on.
Thank you
Thank you
Sep 4, 2023 at 1:40 AM
