Timing belt replacement
107,000 MILES • 3.3L • V6 • 2WD • AUTOMATIC
POTTER130
I have the car listed above that the timing belt went on. I have found conflicting reports online whether it is an interference, or non interference engine. I did try to crank the engine several times after it shut off on me. Is it possible that I damaged valves or any other mechanical parts?
Apr 17, 2018 at 10:22 AM
good evening.
Yes, it is listed as an interference engine. the easy way to tell is to remove the plugs and use a boroscope to look in the cylinders and see if you see any bent valves.
if you have a shop looking at the car, have them check it first before attempting any repairs.
Apr 17, 2018 at 10:34 AM
WRENCHTECH
  • 20,760 POSTS
They could also do a leak-down test to look for valve damage. If the engine was rotated with a broken belt, you can be confident it has engine damage.
Apr 17, 2018 at 1:07 PM
