1994 Nissan Quest
1994 NISSAN QUEST
24,000 MILES • 6 CYL • FWD • AUTOMATIC
QUESTER209
i have a nissan qiest a it wont crank over i put a new timing belt also has a new battery please help
Feb 19, 2009 at 9:44 AM
Did you double check the valve and ignition timing when you installed the T-Belt.
Feb 19, 2009 at 10:05 AM
QUESTER209
yes it was running good since tha problem i let friend use it and he call me that it wonk crank over could it be the head gasket
Feb 20, 2009 at 9:21 AM
Remove all sparkplugs and crank engine over do you see coolant spewing out
Feb 20, 2009 at 10:11 AM
