Ticking noise coming from passenger side, front under valve cover.
2007 FORD F-150
27,000 MILES • 4.6L • V8 • 2WD • AUTOMATIC
WTF323
I bought my truck new in 2007. I don't put many miles as I live a mile and two tenths from work. Actual mileage is a little under 27,000 miles. Over the past year it has developed a tick/knock on the passenger side front under the valve cover. I did a lot of research and decided on cam phasers. I ordered all the necessary parts and tools to replace them and also a repair manual. I got as far as pulling the valve cover off to discover that it does not have cam phasers. I have also read that the VCT solenoids when it goes out causes a tick but I read where to look but are also not installed on my truck. Very confused and what steps do I take next to solve the problem. I have read there are a lot of problems with these motors built from 04 to 08. The truck still looks new no damage dirt or rust. Any help you can give me on tis would be deeply appreciated. It is has been parked for five months. I don't want to cause any additional damage to the engine.
Dec 7, 2014 at 2:58 PM
HMAC300
  • CAR REPAIR CONTRIBUTOR
  • 48,601 POSTS
have a pro look at it, it may be a worn cam/follower due to much wear causing it. driving the distance you do is a death trip on a motor you if you continue after it's fixed. change oil every 3000 miles with filter and drive at least 20 miles on eway once a week. You get to much gas mixed with your oil the way it is now that is probably why it failed.
Dec 7, 2014 at 4:16 PM
WTF323
Thanks for your help. I spoke with a mechanic and suggested that should be my next course of action.
Dec 8, 2014 at 7:33 PM
