Engine cranks but does not start?
177,000 MILES • 3.6L • 6 CYL • 4WD • AUTOMATIC
BWURMIE
The starter is turning I know this because I can see the belt turning. But just the belt is turning it's not turning the engine over.
Jul 17, 2022 at 9:40 AM
SQM
  • 6,383 POSTS
So, the engine is cranking over but not starting?
Generally speaking, you will need spark, fuel and compression for the engine to start.
When you turn the key to the on position, can you hear the fuel pump prime for a few seconds?
If there is a fuel delivery issue, then the engine won't start even if the pump is good.
You can try spraying starting fluid into the intake and see if that lets you start the engine. If the engine starts for a few seconds then the issue is fuel.
Take a look at this helpful guide:
https://www.2carpros.com/articles/car-not-running-advanced
Let me know what you find or if you have any questions.
Jul 17, 2022 at 1:08 PM
BWURMIE
It's turning over loosely like there is no compression it's not turning over its just spinning.
Jul 17, 2022 at 2:02 PM
SQM
  • 6,383 POSTS
If it is turning over fast (the belt is turning), then as you are suspecting, the issue could be compression.
So, a good first step would be to check the compression.
Jul 18, 2022 at 8:09 AM
