the fuse to the AC keeps blowing
185,200 MILES
CGADOLA
i don't really have a lot to say in this block, but it says i need to have 200 charactors so i'm trying to make this long. I have to change the fuse to the AC monthly, it keeps blowing. i googled this problem and it said: you need to buy a volts meter and test the voltage to determine where the short is. there are a lot of wires and looking at all of them would take forever. most of the time it's a loose or cooked wire touching the frame causing it to ground out and DO NOT DO A HIGHER AMP FUSE this could cause a fire or burn into other wires causing more shorts. thank you for any guidance you can offer
Jul 31, 2013 at 10:59 PM
KHLOW2008
  • 41,812 POSTS
If it does not blow immediately, the chances are that it is not due to a direct shorting. A component such ads the blower fan motor could be failing causing the problem. It could also be due to a bare wire that is intermittently shorting.
Aug 1, 2013 at 2:02 AM
