Temperature gauge was working intermittently, code P0128
SATURNTECH9
  • 30,869 POSTS
That would explain the low temperature gauge reading. The thermostat is allowing coolant to circulate at way too low of coolant temperature.
Thursday, November 12th, 2020 AT 10:26 AM (Merged)
2FOOTROPER
  • 6 POSTS
That is not the case as the temperature gauge works fine showing about 190 degrees. After the battery is disconnected and reconnected. After running the car for maybe an hour or so then all of the sudden the gauge goes right to 0. It does not decline slowly. Then after about five minutes the check engine light goes on, the fans run continuously and the AC will not cycle. I can reset the computer and it will be fine for a while then it does it again. Sometimes after twenty minutes or less.
SATURNTECH9
  • 30,869 POSTS
All the GM cars and other cars I have seen set the p0128. On some cars if the coolant is too cold the AC will disabled. So the only code setting is the p0128? If I had the car I would replace the thermostat and go from there. I would also when the temperature gauge was reading low I would see what the temperature on the scan tool live engine data read to actual temperature with a infrared temperature gun. I have seen the PCM go bad and cause this
SATURNTECH9
  • 30,869 POSTS
The coolant temperature sensor you replaced might have a issue who knows. I have seen some weird things happen with aftermarket parts quality compatibility and just plain bad right out of the box or bad shortly after installed.
SATURNTECH9
  • 30,869 POSTS
The engine cooling fan would stay on if the coolant temperature sensor was reading back to the computer like minus forty degrees due to a circuit issue or coolant temperature sensor issue. That is why I am asking if you only have a p0128 still? There are other codes that set for coolant temperature sensor circuit issues like coolant temperature reading too or too low.
2FOOTROPER
  • 6 POSTS
I am replacing the thermostat in a couple of hours and I will see if it solves the problem and let you know.
SATURNTECH9
  • 30,869 POSTS
So what codes are setting now? You said the check engine light is coming on again?The thermostat is not going to cause the radiator fan to run constantly. If you do not live in California you can go to a auto parts store and have the codes scanned for free. I need the exact code numbers not code descriptions.
2FOOTROPER
  • 6 POSTS
I had to get a rebuilt PCM cost me $187.00 all set. All fixed! Thanks for your help I love this site :)
SATURNTECH9
  • 30,869 POSTS
Nice work, we are here to help, please use 2CarPros anytime.
Cheers
STEPHAKNEE
I have had this same problem with my G6. I have had the thermostat and sensor replaced. Worked for awhile then the gauge will work and stop and work and stop. My check engine light comes on like every twenty times it does not work.
Was this ever fixed and completely done with? I have been dealing with this for months!
ROARINGHOOK1214
  • 2008 PONTIAC G6
  • 74,000 MILES
The coolant gage quit working. I have to remove the hot wire off of the battery to get the coolant temperature to keep working. After a while the coolant temperature quits working. Than the cooling fans come on and never shut off at all. Do I have to replace the coolant temperature gage. Or do I have to replace coolant gage sensor to make the gage able to work again. Or could it be a problem with a model or just a dirty sensor wire connection?
Inspect and test the coolant temperature sensor.
GGINAHTJ
Also wanting to know if was ever fixed. Just bought 2008 G6 Friday and Sunday same thing going on check engine and gauge will not move. Taking back to car lot today to make them fix it but probably they have already fixed this issue when they got the catalytic converter and it is starting again. I love the car but do not want to pay a note if this will continue to happen.
  • 110,068 POSTS
I would start with the sensor itself.
2FOOTROPER
  • 6 POSTS
Yes, it was fixed with replacing the thermostat and the temperature sensor.
BIZZYBEE15
Okay, reading through all of this and making my own conclusions. I have a 2008 G6 with 72,000 miles bought it three years ago with no issues until just recently. While driving down the highway my temp gauge dropped from a normal 220-225 down to 0 degrees. I drove it home about twenty minutes and no check engine light came on. Went to the auto store and purchased a temp sensor (ECT), disconnected my battery, and all was well. That was three weeks ago. Just yesterday the same thing happened except my check engine light came on. Now again I am only going to assume that the code is going to be that P0128. But I am going to purchase a thermostat, replace it, and see what happens anyway. If for any reason that does not work, what else should I do?
SHERRY DENNIS
My 2006 G6 temperature gauge jumps up and down and makes the car lag while driving. Code that came up is P1258. Changed thermostat and temperature sensor already. And it is not overheating.
KEN L
  • MASTER CERTIFIED MECHANIC
  • 50,520 POSTS
You need to hook it up to a scanner that will should you the sensor temperature and if it is okay from the computers point of view the computer is probably bad and needs replacement. Check continuity from the sensor to the PCM
Please let us know what happens. I am curious. ;)
Cheers, Ken
SHERRY DENNIS
We replaced the thermostat again and also put on a new water pump. Car runs like it should now. Thank you.
KEN L
  • 50,520 POSTS
Cheers, Ken
