Check for voltage on that wire at the headlamp switch, with the switch activated, if there is voltage, you have a wiring circuit problem. If no voltage, could be the lite switch, itself, or voltage to the lite switch.
I saw where you talking to three or four of us at the same time, different posts. Those other guys are way sharper than I.
Thursday, November 14th, 2019 AT 11:49 AM
(Merged)
