2002 Suzuki Grand Vitara Signals Won't Blink
SUZUKI
ALASKADON
I have a 2002 Suzuki Grand Vitara (Mileage:107,925). When I turn on my hazard lights or turn signals the lights come on but nothing blinks. I bought a flasher replacement at NAPA but their computer doesn't show where to plug it in. Neither does my owner's manual. Did I buy the wrong part? Where do I put it?
Jan 11, 2007 at 11:49 AM
SERVICE WRITER
  • 9,123 POSTS
The turn signal flasher is under the dash on the drivers side near the kick panel here is a diagram below to help you see where they call it a turn signal relay. Check out the diagrams (Below). Please let us know if you need anything else to get the problem fixed.
Jan 12, 2007 at 10:34 AM
Suggested Repair
Locate the turn signal flasher, also called the turn signal relay, under the dash on the driver's side near the kick panel and install the replacement there. Confirm the NAPA part matches that relay.
Conversation Summary
The owner of a 2002 Suzuki Grand Vitara says the hazard lights and turn signals illuminate but do not blink. A flasher bought at NAPA could not be located using the store computer or owner's manual. The expert says the turn signal relay is under the dash on the driver's side near the kick panel.
