1999 Suzuki Grand Vitara 2.5L 4WD Automatic
Problem seemed to start after an oil change at a speedy Oil Change place where they overfilled aprox 2 qts. Engine started smoking at startup for aprox 5 sec.
Determined overfill condition and drained down to full mark.
Still smoked on startup. On accelleration, preignition Knock, (Loud) accompanied by Brown Smoke. On reduction of accellerator sound and smoke ceased.
PCV Valve was completely fouled and replaced. No effect. I'm wondering if changing the PCV while the engine had been shut tdown for 5-10 min might have just pumped rocker arm oil back into the new PCV as the first start after the R&R was clean, no smoke.
Thanks in advance, I also donated.
May 29, 2007 at 10:59 AM
