Huge white smoke is coming out while starting the engine. After some time it reduces and slowly smoke stops. Sometimes there is cylinder miss also. The authorised mechanic says engine has to be opened as mobile is passing through the piston as the vehicle was idling for long time. But vehicle was not idle for even a single day, it was driven everyday though for short distance. This problem started after last servicing when carburator was also cleaned. While running the vehicle everyday , small amount of water is coming out everyday.
Jan 3, 2009 at 3:04 AM
