1992 Other Suzuki Models No Spark
1992 SUZUKI
85,497 MILES • 4 CYL • 4WD • AUTOMATIC
ORTRAVLER
I have a 92 Suzuki Sidekick 1.6L, 8 Valve, automatic, 4WD with throttle body fuel injection. The timing belt was recently changed after failing. After putting everything back together, there was no spark and no fuel pump run. The check engine lite was on all the time. After replacing the ECM, the fuel pump runs for the required 3 seconds, but still no spark and the check engine lite is still on continuously. I have checked the coil, the igniter and all wiring connectors. Now what coach?????? Thanks
Dec 20, 2007 at 9:24 AM
  • 75,988 POSTS
I've reviewed your ignition system and it indicates that you have a crank angle sensor. I recommend you inspect and test it.
The crank angle sensor is in the distributor
Dec 27, 2007 at 4:22 PM
