Sunroof does not close
2001 FORD ESCAPE
130,000 MILES
MARIO LAKO
Hi, so couple of days ago i wanted to open my sunroof and i heard a crack. Now the drivers side goes back but will not come forward. And when i make it tilt only the passanger side rises the drivers does not An hour ago i disassembled it took out the glass, the metal bracket that stops the visor from going to far inside and the visor itself, but found nothing just very small broken parts. I greased up the drivers side but no luck. I tried to pull it forward (the drivers side) manually but it was hard to do.
Apr 8, 2017 at 1:46 PM
HMAC300
  • 48,601 POSTS
unfortunately we show no pictures of sun roofs. best thing here is go online and see if you can find a breakdown to see what has broken. you might try Dorman products to see if they have parts for it.
Apr 8, 2017 at 4:15 PM
