the sunroof wont work. it makes a click sound when i press the button but doesnt do anything else.
Aug 3, 2010 at 2:48 AM
BLUELIGHTNIN6
✓Experienced Mechanic
the click you hear is the relay clicking, when pushing the button do you hear the sunroof motor operating? if not then check the fuses. if fuses are good then sunroof motor will need removed and tested with 12v direct power.
