1999 Subaru Forester Hard Shift
SUBARU
HEYSUZ3
Nine months ago. I bought a used 1999 Subaru Forester to drive back and forth to work. I knew it would need some repairs given it's age and at the time had 123,000 miles. It now has 138,000. I've had the back right rear wheel bearings changed and the catyletic converter replaced along with a leaking head gasket. The transmission is now on the fritz. My garage told me the transmission was going bad when they had it to replace the catyletic converter. When I asked my garage when should I have it replaced, they said when it will no longer pull. They said the AT Oil Temp light was coming on but to ignore it because we already know the transmission is having problems. It's having trouble changing gears and shifting very hard and wanting to slip a bit going uphill. Should I really "wait" until it completely goes or go ahead and have it replaced? I don't want to cause other problems by ignoring this one until the transmission actually goes out. Was this good advice from my garage?
Mar 13, 2007 at 7:46 AM
MIKE H R
  • 3,094 POSTS
has the transmission fluid and filter been changes:? I have a 1999 outback and the at temp light came on , after i had the transmission flushed and a new filter it runs good, does the fluid smell burnt or look dark brown? if so try changing the transmission fluid.
Mar 20, 2007 at 2:33 AM
SCUBARU
  • 71 POSTS
If the trans atf temp light is flashing then there is problem that needs to be diagnosed and you may not need an entire transmission.Lets say a shift silinoid has failed, you will get poor transmission performance.The E4AT transmission in your Forester is controled buy a Transmission control module and if the module sees a problem with a sensor or silinoid in the trans it will flash the light. So my suggestion is have it diagnosed first . What code is set in the TCM and What is causing the code to be set
Mar 20, 2007 at 3:04 AM
HEYSUZ3
Thank you both for your answers to my transmission question. After giving it some thought which was if I don't fix it, it might cause problems with the engine, I took it back to my garage to have the transmission fixed since it was really getting bad quickly. Yes, the AT Oil Temp light was flashing but it I also noticed the check engine light came back on and the gas gauge was going up and down and violent shifting. I told all this to my garage. They had the car a couple of days and finally called me on Monday to say they had checked everything and were stumped so they took it the local Subaru dealer. The problem turned out not to be the transmission but a burned ground wire and burnt wire to the ECM(?). Apparently, when my head gasket was leaking antifreeze back in December, it must have caused the wires to deteriorate and they finally went. The dealer replaced the two wires and she's driving like a little top again. No shifting problems, the check engine light has not come back on and for the time being everything seems fine.
Mar 22, 2007 at 7:38 AM
SCUBARU
  • 71 POSTS
Thats good news.And kind of what i expected as far as Not needing a transmission.
Mar 22, 2007 at 8:40 AM
KLC397
I recently had my head gasket fixed...once my car was put back together the timing was fixed and my car started. It idles fine but when you put it in gear and push the gas the car does not move. I was told that it may be a fuse in my transmission is this possible? I do not know if it matters but while fixing my head gasket my battery blew up could this have interfered with my transimission? This is a 1993 Subaru Impreza hatchback, it has over 200,900 miles.
Apr 17, 2007 at 8:27 AM
2CARPRO JACK
  • 11,533 POSTS
Did they pull the engine to do the head gaskets?It is alot easier on most Subaru's to pull the engine for major work
Apr 17, 2007 at 11:01 AM
KLC397
No we already have the gaskets fixed but once the car was back together it will not move when in gear. I was asking for any answers there may be to help with why it will no longer move. This is an automatic 1993 subaru impreza.
Apr 18, 2007 at 4:22 AM
Suggested Repair
Do not replace the transmission until the flashing AT oil temp light and related codes are diagnosed. In this case, burned ground and ECM wires—likely damaged by earlier coolant leakage—were replaced, which restored normal shifting and cleared the warning lights.
Conversation Summary
The owner of a 1999 Subaru Forester reported hard shifting, uphill slip, and a flashing AT oil temp light. The shop suggested waiting until the transmission failed, while replies advised checking the fluid and diagnosing transmission control codes first. The owner later reported that a Subaru dealer found burned ground and ECM wires, apparently damaged after an earlier head-gasket coolant leak, and replacing the wires fixed the shifting and lights. A separate 1993 Impreza that would not move after head-gasket work was discussed but not resolved.
